Announcements
Can't delete a file because it says it's in use
mikkelr057
mikkelr057
i can't delete a file because it says that is in use but it's not?
i have tried all of the things i read about on the side but nothing works?
jhackney1972
If any VERSION of the file is in use this will prevent you from erasing a file.  So even if you think it is not in use, you will have to go back through each version and see if it is being used.  This is a problem may people face.  I have set up a folder of files like this and placed them there just to get them out of the way.  Fusion 360 will fix this issue eventually so just bear with it.
John Hackney, Retired
