Can't Copy Files "Number of inbound relationships exceeds limit"
Message 1 of 13
I suddenly can't copy any files.  Fusion360 gives me the message "Number of inbound relationships exceeds limit" in the data panel when I try to copy anything.  I also tried to make copies in A360 on a web browser and I just get the message "Copy of filename failed."
Opening a file then using Save As creates a new entry in the data panel, but that entry is stuck with a spinning wheel and v0 no matter how many times I try to save it.
As far as I can tell, nothing's been updated since yesterday when everything was working normally.
Replies (12)
Message 2 of 13
Clearing local cache & pending uploads had no effect.  Moving on to a clean install.
Message 3 of 13
matt.pooley
Hi Kyle,
The error message is suggesting that you have hit a limit on the number of files in a folder (10,000). If that is the case, then copying or saving into a different folder or project should still work.
Does it seem feasible that you have 10,000 files in this folder ? If not then we should investigate what is happening, which would be helped if you could upload your diagnostic logs for review.
Matt Pooley
On Behalf of the Fusion Dev Team
Message 4 of 13
I probably have around 2000 total files on my Team Hub in a few different projects.
Most of my files are linked to a few fixture models.  I can copy the fixture assemblies, and they contain linked components.  I cannot copy any model containing the linked assemblies.
Can I copy it?
Base Component - OK
  Assembly containing base component - OK
     Assembly containing assembly - Fail
My workflow is entirely dependent on making copies of design templates that fall under that third category.
Diagnostic Logs attached.
Message 5 of 13
matt.pooley
Hi Kyle,
Thank you for the logs, I believe I tracked down the reason for the errors. The assembly you are copying includes a number of sub-assemblies that are being used in a very large number of other assemblies. The copy is failing because the number of links to these sub-assemblies (5000+) is hitting an internal limit that we hadn't expected to be exposed in this way.
We believe there is a workaround available, which isn't ideal, but should let you get past this and continue working. If you open the sub-assemblies which are used frequently, make a no-op modification to them, save them, and then perform a Get Latest in the assembly you want to copy, then subsequent copies should succeed. (The reason for this is that we track assembly -> sub-assembly relationships on versions, so the new version of each sub-assembly will reset at a low number of relationships).
Apologies for the need for a workaround, we're going to keep investigating the internal limit on our side and see what we can do to avoid it.
Matt Pooley
Message 6 of 13
Matt,
This workaround is successful.  Thanks!
Kyle
Message 7 of 13
I'm wondering how you're seeing 5000 links to a particular version of an assembly.  I have at most 950 files that reference that assembly.  Is it possible that each version of a file produces a distinct link back to the reference assembly?  For instance, if Part1 has 5 versions in its history, does it account for 5 links to Fixture_assembly?
Message 8 of 13
Note : Accidentally posted using a testing account, this is Matt Pooley from the Fusion Dev Team...
Hi Kyle,
Yes, we do track links between assemblies at the version level, so if versions 1 through 5 of an assembly all use the same version of another design, that will be 5 separate links in our system. As we explored the problem you ran into, the implications of this behavior (and limitation) for a scenario such as standard parts or machine tools became clear and we are investigating what can be done to either remove the limitation or change the behavior. Unfortunately I don't expect there to be a quick fix, but we're looking...
Matt
Message 9 of 13
Solovey.cmf
Observer
Observer
Hi. I seem to have the same problem. But the solution you came up with doesn't work for me. In fact it gets worse. All linked components have been deleted from the model. My work and schedules depend on these models.  I would appreciate help. I am attaching a diagnostic file.
Thanks.
Igor
Message 10 of 13
danieleR9DDN
It seems that I´m having the same problem, it´s 2 days that I cannot figure out why nothing is working here.
Message 11 of 13
Solovey.cmf
Observer
Observer
  1. In the end I was able to solve the problem using the solution suggested in this forum
Message 12 of 13
danieleR9DDN
What is a "no - op" modification? I tried to use compute all and save again, it seems to work at start but later Fusion is nota able to upload the assembly and later show an unresolved  error message
Message 13 of 13
Solovey.cmf
Observer
Observer
I made a minor change to the linked design just to save it as a new version.
