I could really use some help. I am trying to make a replacement door to go on the glove box of my SKi-Doo Snowmobile, to eventually hold my phone in view, but safely out of the cold.
I'm relatively new to Fusion and am having diffuclty Converting my FORM design to BREP so I can turn it into a solid object. When I use the Repair Body feature, it returns the following error...
Conversion error for: Door Skin (Form)
T-Splin topology problem. Use Modify - Utilitites - Repair Body to remove error.
However, when I did this, it clean up a few T-Points, but has not been able to repair enough Star-points I guess to allow this to be converted.
I know you need to minimize the number of T-Points and Star-Points as possible, but I can't think of a way to do this without distroying the shape.
Note: The form was placed over the (still attached) 3D scan of the original dash. So you can see what I am trying to replicate. My goal is to add thinkness (or Shell) to this shape once it has been converted so I can 3D print it. The most important dimensions will be on the hinge at the bottom and the back side where the door will meet up with the mating glovebox. Once this is confirmed to mate up I plan to design a phone holder to place this geometry.
Many thanks as I have been killing night trying to find a solution.
