@masa.minohara Thanks I was about to reply with a very similar solution! The problem is at the edges where the bodies meet, it's causing a solver error. I'll log a bug for it.
@calexpavel Welcome to the Fusion 360 community. Thanks for posting this, what a cool model!
I found that the edges where the lip bodies meet the shell bodies are causing problems.
There are a few ways to tweak the model so the combine will succeed. Masa shows one, this is how I did it a little differently.
- For the top I used Press-Pull to expand the lip 1mm. After the Combine, use Press-Pull to move the face back -1mm.
- For the bottom, Press-Pull the lip face inwards a small amount, like -0.5mm. The Combine will work.
Please keep us posted on your progress, this looks cool. If you have more questions let us know.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
