Announcements
Can't click on constraint in sketch
LeonardSeeling
LeonardSeeling
Hi guys,
I have an incredibly frustrating problem/bug, because of which I can't click on/select any constraints in any sketch and any design. I've already tried messing around with the selection priority modes/settings and nothing worked (also tried restarting Fusion, my PC, etc).
Thanks in advance for any tips on how to solve this.
jhackney1972
You will have to attach your file from Fusion 360 so the Forum users can take a look.  Right now we are blind without it.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section of a forum post to attach it.
John Hackney, Retired
jeff_strater
see this thread:  cannot-edit-sketch-rectangular-pattern-pattern-icon - toggle constraints of and back on until this bug is fixed.
Jeff Strater
Engineering Director
LeonardSeeling
Thanks for your quick response, that fixed it!
