Announcements
Can't calibrate canvas
jeffmorris
jeffmorris
Following a tutorial on modeling a car in Fusion 360, I inserted a canvas that has an image of a car drawing. I tried to calibrate the canvas but I don't see the input box for entering the dimension. How can I fix the problem?
davebYYPCU
Calibrate - uses two pick points on the graphic, when the second point is selected the dimension is waiting with the current value, overtype for the new value, and press ok.
(Might have to zoom out for the value box)
Might help....
TheCADWhisperer
wmhazzard
It looks like a bug, several others report the same problem. Try not to zoom in so far as the points leave the screen.
jeffmorris
When calibrating the canvas, click on the center of each wheel. I don't get the input box for entering dimensions. The wheelbase should be 119".
TheCADWhisperer
wmhazzard
Zooming in to where the first point leaves the screen, the dimension box fails to show.
