Announcements
Can't bend a spline on an aircraft rib flat pattern
Greetings, ladies and gentlemen.
I am having a hard time understanding how "Bend" works when trying to bend a spline.
Here i have a flat pattern of aircraft rib and the only corner i am able to pick for bending is the straight one. Can't pick the spline line.
I understand that this is a very stupid question, but i don't have anyone else to ask, except way smarter people than me on forums.image_2021-07-02_19-41-54.pngimage_2021-07-02_19-41-44.png
jhackney1972
The application will not allow the selection of a curve, spline or otherwise, because this type of bend would result in material deformation.  This is not allow in the sheet metal environment.
John Hackney, Retired
Understood.
Is there any other type of "bend" which i can use in order to bend this whole segment? Or it would be wiser to remodel the detail and use different modelling approach?
I am sorry for wasting your time on my stupid questions 😞
TheCADWhisperer
Model in finished form.
Sweep.
As you wish, sir.
