Can some one describe what exactly is a Unhandled Exception is for Fusion 360.
So I can make out that the app will close. Unexpectedly. I just get some of this error from the temp area. Nothing for this app is unusual to work. All it does is just quit when there are ongoing processes. Usually when I change the perspective of the view on the model. Or it might appear as an issue when I try to make different selections. This only happens when I try to make new solids only. As that is a problem.
I don't even care to attach the log files collected by Autodesk.
I put this exception for no reason. This usually makes no difference to putting together a solution.
Right now the only solution speed I can gain is getting stuck on the character assembly. For inputs of i, ї,
Í í i̇́ Ì ì i̇̀ Ĭ ĭ Î î Ǐ ǐ Ïï Ḯḯ Ĩĩ i̇̃ Į į Į́ į̇́ Į̃ į̇̃ Ī ī Ī̀ ī̀ Ỉ ỉ Ȉ ȉ I̋ i̋ Ȋ ȋ Ị ị Ꞽ ꞽ Ḭ ḭ Ɨ ɨ
ᶖ
<Exception PGStatus="0x00000001" access_address="0x00000000000000d8" accessing_null_ptr="1" code="0xc0000005" exception_address="0x00007FFDFC27E125" text="ACCESS_VIOLATION" type="Read"/>
Also,
error report CER_227737580 to Autodesk
