Can not select through decal even when visibility turned of
If a decal is applied to a surface to a body it will always be selected first even if the body it has been applied to is hidden. It is only when hiding (turn visibility eye off) the decal group in the tree one can select through/behind it. It does not work if the individual decal has visibility turned off.
I have tried turning decals off in the selection filter, no go.
"Select through" on/off does nothing in either case.
I expect the behavior that I can only select geometry in the main window that I can see. If I want to make it visible again I can do that in the tree on the left.
