Fusion Support
Can not insert any of my DXF files since latest update
8 REPLIES 8
Message 1 of 9
rsmith81K6MEG
245 Views, 8 Replies
Every since the last update I can't insert DXF files anymore. This includes all the DXF that I have generated with Fusion 360. Any ideas?
-Ryan
8 REPLIES 8
Message 2 of 9
Please attach a couple of these problem DXF files and let the Forum users take a look.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
Message 3 of 9
It has been an hour since I requested a couple of your troublesome DXF files, can you not share them?  You make a claim that Fusion 360 cannot open them but we have nothing to go on to help you out.
John Hackney
Retired
Message 4 of 9
Sorry, I got busy. Here are 2 examples. The second one the Goodemoot Monogram I just made in Fusion and I can't even reinsert it now.
Message 5 of 9
I am running the latest version of Fusion 360 and I have not issues opening your supplied DXF files.  I assume you are using  the Insert DXF command?  If you are and still having issues I would suspect you have Fusion 360 installation issues and probably should take a look at the Fusion 360 Service Utility.
John Hackney
Retired
Message 6 of 9
One thing just crossed my mind, I installed the windows DXF viewer also. Any chance that could cause an issue?
Message 7 of 9
I have no idea since I do not know what the application is.  If I were you, I would use Autodesk TrueView for DXF viewing.
John Hackney
Retired
Message 8 of 9
@rsmith81K6MEG What happens when you try inserting a DXF? Do you get any error messages?
Mark Hughes
Owner, Hughes Tooling
Message 9 of 9
Yes, I get an error message “Fails to insert this DXF file” when you click on the message there isn’t any detail of why it failed.
