Can not create temp folder archive
kclaeysUWJJL
Observer Observer
kclaeysUWJJL
Observer
Observer
The software refuses to launch, run as normal I get an error saying "Can not Create temp folder Archive"
When run as administrator, CantOpenError: unable to open database file.
Can anyone help with this issue?
sryan@com-sens.eu
Phil.E
Is this a new installation of Fusion 360, or was it running on this machine previously?
Have you tried a full - reinstall?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
lito73VBQ
Hi Phil,
I'm having the same issue today, this is a new full re-install.
Magnus_enbusk
Hei,
I am having the same issue, did you ever manage to fix it?
Phil.E
Does the last post in this thread have any helpful tips?
https://forums.autodesk.com/t5/fusion-360-support/can-t-create-a-temp-archive/td-p/8184649
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Magnus_enbusk
I can run the streamer.exe and I get 3 more % into the prosses. same error thou. (CantOpenError: Unable to open database file)
Phil.E
Just to be clear, you tried this:
I opened the .exe file in 7zip (my zip archiver) and extracted all the files to a folder.  From there I opened the .exe in the parent folder and the update/ install started working.
And you only got 3% more progress? The reason I gave you that link is this issue is known as a 7zip issue that rarely happens for individuals, but not a general problem.
At some point, can you try doing a full clean uninstall/reinstall? The manual steps are listed here.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
