I'm still quite new, so this likely user error, but I cannot reduce a parameter back to a previously used value, only keep increasing it.
I started with someone else's parameterized file, and that shrinks or grows appropriately when I increase the user parameter NumUnitsX or NumUnitsY (by units of 2). I then added a 2nd body, designed as a tray that fits in the first body, to hold screwdriver bits.
Now, if I increase, for example, NumUnitsX from 4 to 8, it works. But when I reduce it moments later back to 4, I get "Warning: Sketch5
Compute Failed
Error: Chamfer2
<b>1 Reference Failures</b><br/>The edge reference is lost, try editing this feature to reselect the lost edge.
Compute Failed"
I have a sketch with an offset calculated off of another sketch to give a bit of tolerance for the 3d printed parts. I think this is the offset that is failing, but I don't know why.
Latest Fusion, Hobbyist, Mac 10.15.7
