Announcements
Can I view user parameters at all times?
fusion36063U99
Observer Observer
fusion36063U99
Observer
Observer
I like to use user parameters for as much as possible, but I have a terrible memory.
At present I go to enter a dimension from the user parameters, I get the drop down but can't remember which user parameter I need.
So I cancel the operation, open the modal dialog, locate the parameter I need (In the dialog I can see the value and also how the value is constructed from other parameters so it is obvious which one I want). I then close this dialog re-do the operation, by which time I cannot remember the parameter, so I have to re open the dialog, check again (copy it to notepad if I'm sensible) and then close the dialog and go back to the operation.
Am I missing a way to keep the user parameters visible at all times? (even if they are read only?)
YoavFriedlander
@fusion36063U99 there is a request for it! - absolutely on the same page - we need it 🙂 please vote for it to help raise awareness - here is a link :
https://forums.autodesk.com/t5/fusion-360-ideastation-archived/parameter-list/idi-p/7601325
davebYYPCU
Your link is dead, (IPad)  probably because the idea station was closed a while back.
YoavFriedlander
Thanks and **** 😕
fusion36063U99
Observer
Observer
Cheers, I have voted for it 🙂
