Can fusion 360 run on Mac high Sierra
Message 1 of 12
Im about to start a new business venture and have been using and running fusion 360 on an old laptop which is struggling currently. I have been offered a Mac Pro running high Sierra. I have seen online that come this month fusion will not be supported on this platform. Would I still be able to install fusion and use an older version of the software on this computer set up or would I be better off looking for a different computer?
cheers
callum
Replies (11)
Message 2 of 12
RajkumarIlanchelian
@Anonymous @If you already had a version of Fusion 360 installed we would let you using that version. Updates will be blocked. We however do not let new install on an unsupported OSX.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
Message 3 of 12
deceliere3UBW6
hello @RajkumarIlanchelian ,
I just updated from 10.12 to 10.13.6.
Fusion was working fine on 10.12 (though no updates possible).
now, it won't let me work anymore without updating, but updating is impossible.
why are you blocking users???
I feel totally despaired, as I have some things to get done, and can't update now to 10.14.
you said you would let users work with previously installed Fusion306 version. but that's not what happened to me, and now I'm stuck.
how can I do?
thanks
regards
Message 4 of 12
RajkumarIlanchelian
@deceliere3UBW6 what is the error or the experience that is happening? We do have customers on 10.13.6 that currently use an older version of Fusion on the OSX.
Autodesk Fusion
Join Fusion Insider
Message 5 of 12
deceliere3UBW6
thanks for your answer.
issue is:
first app loads fine, but then main window is masked, and dialog asks for update, saying "update now or do it later" (first screenshot). I assume that by clicking on the cross on the top right corner, I could go on using the app but then the second screenshot appears and app closes, without more warning.
hope you can help.
thanks
Message 6 of 12
RajkumarIlanchelian
@deceliere3UBW6 Looking into what could be happening.
Autodesk Fusion
Join Fusion Insider
Message 7 of 12
deceliere3UBW6
I discovered that if I use fusion without internet connection, it works fine. but I have no files. it's all online.
I can download it from the cloud, but it's quite a hassle (but at least I can work!). and I sometimes want to export into STL, but I can't find a proper way to do it without being online in Fusion360.
thanks for looking into that.
Message 8 of 12
RajkumarIlanchelian
@deceliere3UBW6 Can you please go online and check if Fusion launches now?
Autodesk Fusion
Join Fusion Insider
Message 9 of 12
deceliere3UBW6
works like a charm!
thanks a lot. (what was happening?)
Message 10 of 12
g-andresen
Browser > body > rightclick > save as STL
günther
Message 11 of 12
deceliere3UBW6
woow!! didn't know that.
thanks
Message 12 of 12
RajkumarIlanchelian
@deceliere3UBW6 Glad it works now but also please keep in mind any other issues, we will not be able to help address it for unsupported OSX.
Autodesk Fusion
Join Fusion Insider
