Camera is far far away from the bodies, I don't see them anymore and can't reset/focus on them
pentouf22
pentouf22
Hello all
I open a project I worked on couple hours ago, and I couldn't see any of my objects in the viewport.
First, I thought it was a corrupted file or something like this, but older version of the project faced the same issue. By testing things, I discovered that my camera was in fact really really far, and I can't find a way to reset it, double mouse wheel tab or CTRL+ALT+R doesn't change anything.
If I open a new or other project project, everything is normal. BUT if I do an "import into current", the camera of the new project is broken too.
I hope someone can help me this. I attached some screenshot for you to see the ridiculous size when I want to create a basic cube + grid numbers.
jhackney1972
Could you please attach one of the models that is giving you  the issue.  If you do not know how to attach your Fusion 360 model follow these easy steps. Open the model in Fusion 360, select the File menu, then Export and save as a F3D or F3Z file to your hard drive. Then use the Attachments section, of a forum post, to attach it.
John Hackney, Retired
pentouf22
Thank you for replying!
I just fixed it actually. Someone from the Fusion Discord suggested that I had an object that was really far, so I deactivated/reactivated everything, and I had indeed an object lost somewhere. No idea how that happen, but it's fixed now 🙂
