Fusion Support
Camera glitching when using the view cube and the cursor leaves the screen area
0 REPLIES 0
Message 1 of 1
theo_bestenlehner
52 Views, 0 Replies
I have a quite annoying problem when using the view-cube to rotate the view in the design window.
As soon as the mouse crosses the screen border, die view glitches to some (random?) angle instead of continuing to rotate normally, since the cube is located on the top right corner it happens like instantly when rotating the view and moving the mouse to the right. It does also happen if you hit the top border (and the left and bottom but there's much more distance to cross there tho).
I did attach a video file of the behaviour.
Edit 2: It's mainly an issue when using a touchpad (because there's very little support for it), with a mouse you can just use shift+middle mouse button to orbit around.
Edit: Here's a link to the video uploaded to Youtube: https://youtu.be/5sFeM9Ve-dw
Seems more usable than downloading it.
0 REPLIES 0
