Fusion Support
Calling out a radius on a print
2 REPLIES 2
jmooresf
75 Views, 2 Replies
Having issues with finding a solid way of calling out a radius on a print. I make drawings and prints for my shop and haven't found a solid way of calling out radii or a radius on my prints. Depending on the way the drawing is laid out, I don't always have enough room to write it out and can confuse the guys out on the floor as making them think that the drawing as pictured below is calling for the .120 as the diameter instead of using .06" as a called out radius. Thanks!
Tags (1)
2 REPLIES 2
TheCADWhisperer
in reply to: jmooresf
@jmooresf
Right click when placing the dimension.
You should get option for radius or diameter.
jmooresf
in reply to: TheCADWhisperer
Thanks! That works!
