C-PATTERN 1/C-PATTERN 2 error continually
mavericklast5
mavericklast5
Attempting to create a diamond and in the tutorial once I attempt to use a  circular pattern it fails It also will not naturally select it a point at an intersection
davebYYPCU
Project the point, you need to snap to into the current sketch, otherwise it goes as per video.
Make the 3 panel segment, then pattern that pie shaped body.
Might help....
jhackney1972
Please attach your model so the forum users can diagnosis your issue.  If you do not know how to attach your model, open it in Fusion360, select the File menu and then choose Export and save the .F3D file to your hard drive. Then use the Attachments section of a reply forum post to attach it.
John Hackney, Retired
mavericklast5
The file
jhackney1972
I am sorry, I do not see it.  After attaching it, you should see it below where you attach, then Post your reply.  Please try again.
mavericklast5
It should be below this post
jhackney1972
Ok, got your model and created the changes I think you indicated.  I have attached your modified model with a different name.  There are more than one way to do this operation but I chose to use a body cut using a surface.  All in shown in the Screencast.
