Announcements
Bugs when recomputing
jrychter
jrychter
Ok, here's a good invariant to test for. I'm looking at a flawless history. If I right-click on a feature (say, an extrude), chose "Edit", and click "OK" without changing anything, that should not break anything. And it doesn't, which is good.
But if I click in one of the text boxes (with parameters of the feature), press Cmd-A Cmd-C, click again and click "OK", that should not break anything either, right?
Well it does. See attached screen recording.
jeff_strater
did you verify in the parameter dialog that what you expected to be there for that Extrude feature offset parameter was actually there?  I wonder whether something happened in that Cmd-A Cmd-C action that changed the value.
Also, please share your design.  It's hard to debug just from a video.  Thanks.
Jeff Strater
Engineering Director
jrychter
I reproduced this problem multiple times, because it was so bizarre. Each time I painstakingly checked if the text box contained the same thing that it did before. Why painstakingly, you ask? Well, because the incredibly clunky UI only shows a tiny part of my text, MacOS keyboard shortcuts do not work, so navigating the text field is a pain. But it's possible.
In other words, yes, there was no change in the parameters, but the build broke anyway.
