Fusion Support
Report issues, bugs, and or unexpected behaviors you’re seeing. Share Fusion (formerly Fusion 360) issues here and get support from the community as well as the Fusion team.
Bug with Sweep Feature
5 REPLIES 5
robertASTUP
216 Views, 5 Replies
robertASTUP
I am getting this weird behaviour in Fusion360 when applying a sweep as shown in the attached video. I have found that if I go to edit the sweep after and press ok, the issue resolves itself. This was only by luck that I found that selecting edit sweep, making no changes, and pressing okay fixed the issue. Can this be looked in to so the sweep behaviour is correct the first time around?
Rob
EDIT: Attached f3d
Rob
EDIT: Attached f3d
5 REPLIES 5
g-andresen
in reply to: robertASTUP
g-andresen
Please share the file for reply.
File > export > save as f3d on local drive  > attach to post
günther
günther
robertASTUP
in reply to: g-andresen
robertASTUP
Updated with f3d.
Updated with f3d.
jhackney1972
jhackney1972
Edit your Sweep Feature from the timeline and remove the Chain Selection option. This is a one way correction, if you turn it back on, the sweep will not go back to the error condition.
John Hackney, Retired
g-andresen
g-andresen
simply fully define sketch 1
günther
günther
robertASTUP
robertASTUP
Hi All,
Thank you for your explanataions, videos and efforts to help me solve this problem.
Although I can now get the sweep as desired, it is still not clear to me why when I go to edit the (incorrect) sweep, make no changes at all and then press okay the sweep is suddenly correct. If no settings have changed why would Fusion 360 change the extent of the sweep path? I am unsure is this is a bug or just a glitch as a consequence of the partially defined sketch I have made.
Thanks again for all your efforts in assisting me with this,
Robert
Hi All,
Robert
