Announcements
Bug when making contour inside a hole
anwi9858E
anwi9858E
This is a great program but I ran into an issue:
I made a simple 2mm piece with filleted corners and a 8mm hole in the center. Manufactured with 2D contour and multiple passes (0.5mm). Selected upper and lower edges on both the hole and outside.
The holes only got 2 rounds but the outside did all rounds and was processed correctly.
This can be view by Simulation so it is not a post processor issue.
Anders
Sweden
jhackney1972
The forum users need your model to trouble shoot the issue
John Hackney, Retired
anwi9858E
Is this the correct files?
HughesTooling
You should only select the contours at the bottom of the part. Also Tool Orientation is only used for 4 and 5 axis machining, for 3 axis machines the orientation is set in the setup.
Mark
Mark Hughes
Owner, Hughes Tooling
anwi9858E
Thanks a lot!
