Bug using Shell on lofted pipe.
HughesTooling
Consultant Consultant
HughesTooling
Tring to help someone create a tapered helical pipe. Shell would have been the simplest option but creates a bad body.  File's attached.
I can workaround this using 2 lofts, just reporting the bug in this post. I suspect part of the problem is because the loft twists as it follows the path. Sweep has an option to use a guide rail to stop this, is there any way to do the same with loft? Creating 2 paths is not going to be easy for the part as the profile changes diameter.
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
amaglim
After some analysis I have found it is only a visualization problem. The model is correct. For example a section of the model produce a correct result:
Your solution to split the body looks good.
HughesTooling
@amaglim Thanks for looking at this. After your answer I thought I'd try adjusting the Display Detail Control and set it to High rather than adaptive and that fixed the display of the part.
Mark Hughes
