Here's the object from the attached file:
This a flat-washer shape with a single thin extrusion operation applied to it. The selected profile for the thin extrusion is one face of the "washer". As you can see in the image, the outside of the profile gets the requested 1mm thickness but the inside is double thickness.
Incidentally, it would be really nice to be able to select model edges as input for thin extrusions, for example, if one wanted only the inner or outer cuff for the object above. Does F360 have the concept of "edge chains that form valid profiles?"
