Announcements
Bug. Sketch in drawings workspace.
HughesTooling
HughesTooling
@ClintBrown3D
In a sketch in the drawings workspace, I noticed you can not select a line to add a dimension if a dimension leader is on top of the line.
Can't select this line.
If I move the dimension it works fine. Also note dimensions in the sketch are in inches but in the drawing is mm. I know this is because I'm using the AMSE template but surely it should be possible to use the same units the drawing is set to?
In the example above I'm experimenting creating an accurate section line (see troubles in this thread because of projected vs aligned sections). What I notice is lacking is no way to parametrically reference geometry in the drawing. Need to be able to project lines etc. from the drawing into the sketch. I can snap to points but there's no link to the drawing so everything is floating.
I know there was a recent update that made the sketch in the drawing workspace parametric, are more features going to be added to make the sketch in the drawing workspace on a par with sketching in the design workspace? Like parameter manager etc.
Just noticed in my example after creating a section line on top ot the sketch I can no longer select the line in the sketch.
Mark Hughes
Owner, Hughes Tooling
Replies (10)
ClintBrown3D
Hi @HughesTooling
 @sandip_dumbare is the drawings product manager, I have moved roles. I'm sure Sandip and @liang_chen (QA) will take a look for you.
Clint Brown
Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
sayali_todkar
We apologize for any inconvenience caused. I've reported the defect for both issues mentioned with the tracking ID FUS-196671:
  1. Sketch line overlapping with dimension leader
  2. Sketch line doesn't allow editing when overlapping with section line
For the second issue, you can try this workaround: Select the sketch node from the browser to highlight the line. Once line gets highlighted you can edit it.
Please let me know if this workaround works for you or if you have any comments.
Thank you for your understanding and patience.
Does work but selects all lines in the sketch. In this case I just wanted to change lines to hidden so worked OK.
Might be useful to have a line type that would not show in the drawing. Say construction line type for example.
Mark Hughes
@sayali_todkar Could you take a look at this post and the thread please? We really need a way to create a section that is parametric and updates to match the model. So one thought would be could the section tool be enhanced so you could pick a polyline from a sketch either created in the design workspace or the drawings workspace?
Note the drawings workspace sketches are not parametric at the moment and would need the ability to create projected geometry from the drawing.
Mark Hughes
anirudha_kul
HughesTooling
@anirudha_kul Could you take a look at the post I just made above yours please? This thread was really create because I was looking for an accurate way to create section views.
Thanks Mark
Mark Hughes
sayali_todkar
Thank you for your patience. If you are satisfied with the solution provided for the current issue, please click on "Accept Solution."
Regarding your query about the section view, we will get back to you shortly.
Thank you for your understanding.
Best regards,
Sayali
sandip_dumbare
@HughesTooling
Hello Mark,
The current behavior is: 90 degree lines give orthographic projections. If any of the lines are not horizontal/vertical, the result is an aligned (unfolded) section. This is as designed.
Thanks for suggesting the enhancement. Every customer request that we get, from meetings, emails, forum posts etc. gets collected and categorized in our feature request database. This information is used to prioritize the features that we build next. I've added your request to our database.
Sandip Dumbare
EDIT I tried to attach the file but the forum blocks the f3z file type!🤣
@sandip_dumbare You direct messaged me about the need for a parametric section that updates when the model is modified. I'm quite busy at the moment so don't have time to setup a meeting so I've made a model and drawing to demonstrate that I'll share here.
Take this for example.
First problem would be you would not be able to create this section at an angle and keep all the changes in direction at 90° because the section tool only snaps to vertical\horizontal. It does not snap to perpendicular to existing section lines.
To work around this problem you might want to try using a sketch within the drawings workspace but then you run into the problem that you can't project references from the drawing into the sketch, so when you try setting the sketch up everything moves. Also would not update with model changes.
I notice while trying to make the sketch in the drawing workspace the midpoint constraint is missing!
So to workaround the limitations is sketches in the drawing workspace the only option is to go back to the design workspace and create the sketch for the section.
This works OK and you can pick on the corner point to setup the section.
Trouble is if you modify the body the section has to be manually updated. Obvious if a big change but a small change to the design can catch you out.
I've attached my example drawing.
Mark Hughes
@sandip_dumbare I just remembered I can change the file extension from f3z to zip and attach. Just make sure you change it back to f3z before uploading to your hub.
Mark Hughes
