Fusion Support
bug: Sketch dimension "over constrained", even though it is not
5 REPLIES 5
rangorino
222 Views, 5 Replies
[see .gif] Sketch dimensions have recently been able to both be unconstrained, and also not constrainable, because the Sketch environment thinks it would over constrain the sketch.
have experienced this a lot lately.
Fusion 360 2.0.16009 x86_64 [Rosetta 2]
macOS 13.2.1 (22D68) on MacBookPro18,1
5 REPLIES 5
g-andresen
in reply to: rangorino
It is somewhat strange that after removing the offset dimensioning the relationship is preserved.
Therefore:
remove offset constraint
@jeff_strater    > is that supposed to be?
günther
davebYYPCU
in reply to: g-andresen
I think that is expected behaviour,
because Offset value is missing, replace it, to place outside circle, or
Deleting Offset Constraint, allows diameter dimension.
Might help....
rangorino
in reply to: davebYYPCU
I'm very confident that until recently, the (expected) behaviour was that deleting a dimension related to an offset constraint would automatically remove the offset constraint.
Even if this is the new expected behaviour, it is illogical that the path is constrained with an offset, if the dimension does not exist, in my opinion.
g-andresen
It has never been like this.
…. it is illogical that the path is constrained with an offset, if the dimension does not exist….
I also see it that way.
günther
TheCADWhisperer
