Announcements
Bug - Show dimension in lower right corner of canvas
kal_joseph.edly
kal_joseph.edly
Normally when you click on an edge, curve or face it shows the associated length, radius or area in the lower right corner of the canvas. For the last week or so Fusion doesn't seem to be doing this.
Through playing around I've found that if I click on a single feature the dimension isn't shown, but if I click on another feature immediately after that it will show it. It's less frustrating now that I've figured out you can click around a few times to show the dimension but the previous behavior showed the dimension on the first click every time and was quite handy.
johnsonshiue
Hi! I cannot seem to reproduce the behavior on my Windows machine. Please take a screenshot and share it here. Forum experts can help take a look.
Many thanks!
Software Test Engineer
kal_joseph.edly
Hi Johnson, thanks for following up.
https://autode.sk/3ylZdBp
See link for behavior. To add another wrinkle, when I went to use screencast it had me resize the window to a 16:10 ratio and when I did that the show dimension feature in the lower right actually works correctly. So, it looks like the bug only happens when in a full screen (maximized) window.
This second video is in a less than full screen window showing it working normally.
https://autode.sk/3P86MRX
