Fusion Support
Bug report - Rendering on CPUs with P-Cores and E-Cores
1 REPLY 1
phone_esra
244 Views, 1 Reply
Yesterday I switches to a i5-13400F with 6 P-Cores and 4-E-cores.
While rendering only the (much slower!) 4 E-Cores are involved, not any P-core.
I tried to set the number of processors to manuell in the preferences -> no effect.
I'm on Windows 10 pro 22H2 (all updates) and Fusion 360 2.0.15995 x86_64
All power settings are set to "high performance"
So this CPU is a real "downgrade" in Fusion 360 😕
All other applications are running fine (i.e. benchmarks, all cores are used)
In the german support forum there are also people suffering from CPUs with e- and p-cores.
Regards Matthias
1 REPLY 1
Alex204010
in reply to: phone_esra
The only workaround I have found is to disable E cores in the bios if you want to do a render. There are several tutorials online on how to do this, just search "How to disable E cores".
