Announcements
Bug report: Measure Dialog does not display correct precision
amasters
Message 1 of 9
amasters
So after the latest update, the Measure Dialog does not display the precision chosen from the drop-down.  I was frustrated because I had created a hole with dia. 0.0985" but when I measured it later, it kept giving me 0.099" no matter what precision I had chosen.  If I go into Preferences and change the General Precision to 4 or 5 digits then the measure Dialog displays 4 or 5 digits as chosen.  Seems like the precision in the Measure Dialog does not function at the moment.  Tried this on two different PCs with the same result.
Attached screen shot shows I have chosen 6 digit precision in the Measure Dialog but it is only displaying 4.
Andy
Replies (8)
Message 2 of 9
jhackney1972
I agree this is a bug in the Measure command.  As a work around, go to your Preferences and under Units and Value Display, change the General Precision to what you desire and you will get a better answer.  The Measure Precision entry does not see to be connected to the application at all.   @jeff_strater I hope you can log this to be fixed.  Thank You.
John Hackney, Retired
Message 3 of 9
jeff_strater
the team is looking into it.  Nothing to report yet.
Jeff Strater
Engineering Director
Message 4 of 9
amasters
Thanks Jeff,
Also, I noticed that if you check the "Secondary Units" checkbox in the Measure Dialog, then the secondary units in parentheses will display with the correct precision. The primary units are still wrong.  See attached screen grab.
Andy
Message 5 of 9
jeff_strater
it looks like this bug has been fixed in our internal builds, but we are verifying the fix.  It should be fixed in an upcoming release, though I am not certain of exactly which update.  Thanks for your patience.
Jeff Strater
Message 6 of 9
HughesTooling
@jeff_strater  Have they also fixed the problem for the angle display? That bug has been in Fusion for years!
Thanks Mark
Mark Hughes
Owner, Hughes Tooling
Message 7 of 9
jeff_strater
yes!  The angle precision bug has also been fixed.  A small thing, but glad to have it correct again...
Jeff Strater
Message 8 of 9
Phil.E
Hi again. This week Fusion 360 had a major update to build 2.0.8749. This issue should be fixed in this latest update. Please update Fusion and let me know if you still find the same problem.
Verifying build number:
  • Help > About
  • Look for a number like "2.0.8XXX" in the about box.
  • Current build is 2.0.8749
Updating Fusion 360:
  1. Start or restart Fusion
  2. Look at the Job status icon (the small clock in the top bar)
  3. If an update is downloading a small 1 appears on the clock.
  4. Click to see progress and restart message when it's done.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 9
HughesTooling
Hi @Phil.E  Just tested it works correctly again, also notice precision works correctly on angles at long last! 👍
Thanks Mark
Mark Hughes
