Bug repeatedly causing freeze and crash
Have found a consistent issue causing a total freeze of program causing me to have to force quit and lose unsaved work on Windows 10. The issue happens when in the drawing environment. If I select a dimension and go to edit the tolerance, now I want to change from deviation to symmetrical so I use the dropdown menu to switch to deviation. Default is filled in as .01 for upper and lower tolerance but say I want +0 -.005 well I erase the .01 in upper leaving it as .0, then I click on lower tolerance and start to backspace, as soon as I delete the 1 from .01 the typical behavior is for fusion to see both the .0 as the same and switch itself back to symmetrical (an annoying behavior on its own, I didn't even have a chance to type them in differently) but for the last few months if I do that when it switches back it completely freezes and I have to close fusion. I am given the option to save changes to the drawing but the changes never actually save and I have to force quit the program. Currently the workaround is to avoid having the upper and lower tolerance boxes have the same value, but that's a hard habit to develop.
