Announcements
BUG Offset Plane
wmhazzard
BUG Offset Plane
wmhazzard
Offset plane does not update if you go back in the timeline before the offset plane, use the offset face tool on the same face and move forward, the plane stays at the original location. A compute all does not fix it but if you right click and edit the offset plane, do nothing and hit OK, the plane updates.
Rushikesh.kadam
@wmhazzard I am able to reproduce the case. A ticket is created and assigned to the concerned team. Thank you for reporting it.
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
