Bug: Not all threads showing in drawing
Hey,
I have a part where I´ve added multiple threads, all done the same way and working nicely in the model.
I´m now doing a drawing of that part and not all threads are showing, only some (within the same view).
One is being viewed head on (threads not showing) and one in a section view along the thread (thread showing).
What´s causing it and how can I fix it?
Don´t know why the screencast got lost in the first post.
innovatenate
Autodesk Support
Autodesk Support
I think this may have something to do with the fact that the cosmetic thread that isn't working is going through a circular face.
I can reproduce the behavior quite easily with the attached simplified design. I'll have to check in with development to see what the expected behavior is and circle back.
Nathan Chandler
Principal Specialist
nick.ni
Thank you for reporting this issue. It can be reproduced in my build. We will look into this issue as soon as possible.
Nick Ni
Product Owner
Quality Assurance
Autodesk, Inc.
nick.ni
We've fixed this issue in our internal build. You might see the correct behavior in the next version of Fusion 360.
If you want to fix this issue in your legacy drawing, you need to open the drawing, double click the view to invoke Edit dialog, make a switch of the view style and go back to the original  style setting. You will see the thread is updated after clicking Close button in the dialog.
Thank you again for reporting this issue.
Nick Ni
Product Owner
Quality Assurance
Autodesk, Inc.
