Announcements
BUG: Mac Fusion 360 Fails to Restore State on Reboot
asherFTSTR
asherFTSTR
Reloading Fusion should restore the same state it was in when it was closed, as set in Mac OS system preferences.
Fusion 360 fails to respect this setting and opens a new document, failing to open prior documents.
TrippyLighting
Fusion 360 has never done that and It can be assumed that is as intended.
Perhaps hold of a little on the bug reports until you have more seat time with Fusion 360 and know what the intended behavior is rather than how you would like for it to behave.
asherFTSTR
Failing to comply with OS norms is a bug.
The OS has a setting: "restore open windows on reboot". Fusion does not respect this. That is a bug.
As far as broken behavior— it doesn't matter if the broken aspect was as intended, it is still broken.
I will continue to report broken behavior. If Autodesk chooses to neglect these reports, the neglect will at least be publicly documented.
TrippyLighting
Well, I am so glad to have you here on the forum and look forward to your valuable contributions!
asherFTSTR
If Fusion implemented the Mac OS document model correctly, this bug would be fixed for free.
