Message 1 of 14
I have a closed T-spline body, which I modified slightly - no sign of self-intersections. I was prompted to upgrade to a new T-spline representation. I accepted. The new object looks honkey-dory - no self-intersections. As I tried to exit form-mode I was met with the error message:
Conversion error for: XXX
T-spline surface has no topological components.- I copied the object and started removing faces from the new copy using a bisection method. This gave me a minimal area whose removal allows the then open surface to be converted. The area contains two adjacent polygons. But I can't figure out to fill the hole - to obtain a closed surface - without the above error to re-occur.
- I tried to save the original T-mesh in the internal format -- saw that discussed somewhere -- but that functionality seems to have disappeared. Instead, I saved it as an .obj file. Upon reading that file, I get an object that appears with a negative volume -- it also appears to have a couple of strange polygons that seem to have nothing to do with the original mesh. These do appear to form self-intersections. In other words, the conversion to new T-spline appears to mess up the geometry or topology.
- Thus, I believe that the T-spline upgrade routine contains a bug.
