BUG - Fusion 360 only renders on E-cores (OR on P-cores when switching)
phone_esra
phone_esra
Even on the newest version (v.2.0.17954) – November 30, 2023 Fusion 360 renders ONLY on E-cores.
Because I can turn E-Cores on/off by BIOS settings (Scroll Lock Key switch E-Cores on/off) I've done following record:
On default settings (all CPUs with E-cores) Fusion360 renders *only* on E-cores! This will waste an *lot* of time.
You can see on my picture:
I started with e-cores ON (default), switched to E-cores (OFF) and on again.
On my i5-13400F on default settings, the rendering is done only with 4 e-cores instead of the 6/12 p-cores! Even a 15 year old IntelCore Duo is faster than this. So if your BIOS doesn't have this settings you will wait forever.
OP: Windows 10 Pro, 22H2, Build: 19045.3803,
ASUS Prime B660M-A D4, bios date 09/08/2023
HughesTooling
This has come up before and seems to be controlled by the OS (same problems with games as well if you do a search). Seems you need Windows 11 for better utilisation from what I've seen in other threads.
Mark
Mark Hughes
Owner, Hughes Tooling
phone_esra
indeed...I have updated to Win11 and now all Cores are involved.
(Cross fingers, that all other programs will work, especially the CAM stuff....)
Thanks and regards Matthias
