[Bug] Fusion 360 becomes unresponsive after launching on secondary display
Message 1 of 9
(Creating a bug post for tracking. Sorry if this is not the way to go)
https://forums.autodesk.com/t5/fusion-360-support/not-responding-on-launch/m-p/9482603/highlight/fal...
I have personally experienced this issue and found that the solutions in this thread work for both F360 and Ultimaker Cura.
Users on the Cura Github have suggested that updating the version of Qt used might be a possible solution to this issue
https://github.com/Ultimaker/Cura/issues/4427
Replies (8)
Message 2 of 9
Phil.E
Please check to be sure you have the latest Fusion 360 version. Under Help > About, there is a build number. It should be 2.0.8624 right now.
I'm asking this because I cannot reproduce the issue, and Fusion is already using that version of QT. Please let me know what you find, glad to track down the problem with you.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 9
Hi Phil
Thanks for the reply. I can confirm that the issue persists on version 2.0.8624. Launching on my secondary display causes the unresponsiveness but if I can move the window to my primary display in time, it launches fine.
Cheers
Achu
Message 4 of 9
lance.carocci
Hi @Anonymous, would you be able to take some process samples for me to share with the dev team?
You can do this by accessing the Task Manager, go the the Details tab, right click on a task and click Create dump file.
We are looking from samples from a few files, from both Fusion 360 and Cura, to compare.
  1. The Fusion/Cura.exe itself, when frozen at startup
  2. QtWebEngineProcess, under the same conditions as (1)
QtWebEngineProcess is part of the underlying GUI framework, but uses OpenGL instead of DirectX, so both processes may give us different indicators.
The files produced by these process dumps can be quite large, sometimes 500MB - 2GB - I recommend uploading them to your A360 drive and sharing a link to keep things easy.
Lance
Lance Carocci
Fusion QA for UI Framework/Cloud Workflows, and fervent cat enthusiast
Message 5 of 9
I've uploaded them to A360 but I don't see how to share a link to the folder. It's in the Demo Projects folder under Dumps. Here's the page URL from my web browser if that works?
https://myhub.autodesk360.com/ue283a031/g/projects/D2017012059531931/data/dXJuOmFkc2sud2lwcHJvZDpmcy...
Message 6 of 9
lance.carocci
Give this a try - navigate to the file Overview within A360. Next to the File Size should be clickable text that says Share Link: On/Off. That should open the sharing panel (you might need to play with your browser filter/blocking for it to display).
Lance Carocci
Message 7 of 9
Ah. I was looking for a way to share a folder. Here's the files
Cura https://a360.co/2P1mgte
F360 https://a360.co/2X4yCFA
QT1 https://a360.co/30Qr0rk
QT2 https://a360.co/331n4H0
QT3 https://a360.co/331bE62
Message 8 of 9
Phil.E
Thanks everyone for your patience and help tracking this down.
Please review this article and let us know if it helped you get past this issue.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Fus...
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 9 of 9
It worked! Thanks!
