BUG: edit circular pattern > impossible to select more than one feature
captainfalcon92
captainfalcon92
Experienced bug :
Upon creation, one can select multiple features to add to a given new circular pattern.
Editing will only allow for select one - and only one single - feature.
  1. First create a new circular pattern.
  2. Select multiple features to revolve. Apply.
  3. Now edit the pattern and re-select desired features.
  4. Try redefining which features to revolve by double-clicking the Object: [select] button.
    You can't.
You will not be able to select more than one, that is holding [ctrl], dragging a selection, clicking the view or the feature timeline... None will work.
This has to be the most annoying bug i encounter - every time - always - for years since i began using F360.
One must delete the pattern feature and start over, making sure to select all features to pattern again.
The only work around i found is to use feature groups.
Delete/expand a feature group. Add or modify features, add them back inside a group then apply pattern of the whole group again.
Please try at home, reproduce, then fix.
Best.
jhackney1972
I do not see any issue with the Editing of a Circular Pattern process with multiple features.  I demonstrated this in the attached Screencast.  Please attach your model so the Forum can possibly see your issue and help.  Model is attached.
John Hackney, Retired
jeff_strater
same here - it seems to work fine for me.  You do have to hold down CRTL/CMD after the first feature selection, but I can add as many features to the circular pattern as I want.  As @jhackney1972 requests, please illustrate this with a screencast.  Thanks.
Jeff Strater
Engineering Director
