Fusion Support
[BUG] Drawing attributes not populated for linked sheet metal components
14 REPLIES 14
Message 1 of 15
gvisca44
348 Views, 14 Replies
Title kinda says it all.
When creating a drawing from a model that has linked sheet metal parts, attributes are not populated (part name, part number, etc.).  All we see is ####.  Conversely, the attributes for the folded model ARE populated.
However, internal sheet metal parts have attributes populated correctly.
Glenn.
14 REPLIES 14
Message 2 of 15
ClintBrown3D
in reply to: gvisca44
Hi @gvisca44
Please send me a link to the dataset, I'll ask the team to take a look at it. Feel free to send it directly to me Clint. Brown {a} Autodesk.com
Message 3 of 15
gvisca44
in reply to: ClintBrown3D
@ClintBrown3D
Did this ever get logged as a bug Clint ?
Message 4 of 15
gvisca44
Attaching template ... rename .zip to drawing template.
Message 5 of 15
gvisca44
To keep track of whats happening with this - Audodesk can see the problem with folded models linked into other model and has logged the bug FDWG-16134 for tracking.
Message 6 of 15
gvisca44
@ClintBrown3D
has bug FDWG-16134 been resolved in the Jan23 release ?
Glenn.
Message 7 of 15
Pramod.kadam
Hi @gvisca44 ,
The bug FDWG-16134 is not resolved with Jan 23 update. We have moved this to top of our backlog and will work on this soon. We will update you as soon as we resolve this.
Thank you for your patience.
Pramod Kadam
Product Owner
Fusion 360 Drawings
Message 8 of 15
gvisca44
Hey @Pramod.kadam ,
has bug FDWG-16134 been resolved in the recent releases ?
Message 9 of 15
Pramod.kadam
Hi @gvisca44 ,
Yes, this is fixed. Please check and let me know if you still face an issue.
Pramod Kadam
Product Owner
Fusion 360 Drawings
Message 10 of 15
gvisca44
@Pramod.kadam & @ClintBrown3D - issue still exists !!
Message 11 of 15
Pramod.kadam
Hi @gvisca44 ,
This is strange. Please see attached video recorded on current Fusion build. This works fine for me.
Can you please share the recording and dataset to understand the issue?
Pramod Kadam
Product Owner
Fusion 360 Drawings
Message 12 of 15
gvisca44
in reply to: Pramod.kadam
@Pramod.kadam
I think the difference is:
* You're creating a single part drawing from "scratch".
* I'm creating a multi-part drawing from a template (which I've been using for some years).
I tried a single part drawing using my template (and choosing the flat pattern) - and the component properties were shown (refer first video - file name ends in 940).
I then tried the whole assembly - and on the linked components - properties were NOT shown.  But theyre ok on local components (refer second video - file name ends in 235).
Message 13 of 15
Pramod.kadam
Hi @gvisca44 ,
I found that this workflow is not working on my end too. We will check this.
Thanks for reporting and apologies for the issue, we will update you on this.
Pramod Kadam
Product Owner
Fusion 360 Drawings
Message 14 of 15
gvisca44
@Pramod.kadam  / @ClintBrown3D
I realise you guys have been busy with drawing automation (nice job BTW).
Has the above issue been fixed ?
Message 15 of 15
Pramod.kadam
Hi @gvisca44 ,
Thank you for your comment on Drawing Automation work.
You have asked this at right time, the fix for this problem is ready and going through validation. However you need to wait until May release considering the release cycles.
Pramod Kadam
Product Owner
Fusion 360 Drawings
