BUG: Cylinder primitive discards diameter expression, also does not support parameter naming.
Reproduction:
- In the solid workspace, create a cylinder primitive.
- Use a non-trivial expression for both the diameter and height (eg, reference other parameters, or use a math function).
Once the cylinder is created, examine the model parameters. The height correctly retains the original expression. The diameter incorrectly stores only the evaluated result of the expression - I would expect it to store the full expression.
Also, using the parameter assignment form when dimensioning the diameter (eg, entering "MyParam=1234") is not accepted as valid input (it shows red).
