Bug - Crash when network drive not available
larrybud2004
larrybud2004
When the last saved-to drive is not available when using the "Save as Mesh", Fusion crashes.
e.g. I have a share:
\\myserver\myshare
I Save as Mesh to that path fine. The share disappears (e.g. you didn't log into the share), next time you "Save as Mesh", fusion will crash because it cannot find the share.
Fusion should default to c:\ drive if path is not found.
Phil.E
Thanks for posting this. I'm looking into your crash reports, thanks for sending those.
Are you referring to a couple crashes you reported on February 8?
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
HughesTooling
@Phil.E  This is a very old bug that comes up at least a couple of times every month!
There is a fix in this thread that will get Fusion working again by modifying a line in this file, NMachineSpecificOptions.xml.
Mark
Mark Hughes
Owner, Hughes Tooling
Phil.E
@larrybud2004 Do you have an app called Chitubox installed?
The crash is logged as FUS-122777
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
larrybud2004
No, I don't have that app installed.
Phil.E
Thanks for letting me know. If you happen to crash, please provide the report number so I can look it up and see what may be happening.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
