Announcements
BUG: Cannot select half the features in the timeline when on 2nd screen
tonySWCR2
Message 1 of 1
tonySWCR2
Been working on Fusion for about 4 hours, everything running normally. I rolled back the time line to add a feature and suddenly I couldn't select anything in the timeline, not even the current position marker (or whatever it is called). I saved, closed and reopened the part, no change. I closed and reopened Fusion, no change. I then googled the issue and found previously people had an issue with the window being maximised, so I tried this and now it gets weirder. If the window is maximised, i can select half the features in the time line, If I detach it and make it anything but full screen I can select the other half but not the ones I can select when maximised. This is on my 2nd screen, if i move the window to my 1st (main) screen I can select everything. Now going to restart my computer to see if it persists but screencast attached.
Replies (0)
