Bend lines hidden in flat pattern are showing up on exported DXF fileBend lines hidden
Bend lines on export
You can create a projected sketch and save it as DXF. Please see this article for reference:
So is this a bug, or an intended feature? If it's a feature it's not a very good one.
I have the same is issue. The extended bendlines show up in the DXF even if they are hidden in the flat pattern. And making an projected sketch of every single bended item is a ugly work around to my opinion
Is this something that will be fixed/changed in the future? So specifically export the DXF as to how you have it set/up and shown in Fusion ?
