I'm not a power-user, but I have been using Fusion for several years. About a week ago, I began having trouble opening Fusion, then found it extremely slow to open projects, and impossible to save projects. This happened when the last update wash pushed, but now I think this may be coincidental timing. The root issue seems to be something with the Autodesk account (hobbyist/maker) I'm using for Fusion. After searching through the logs, I found repeated HTTP errors.
What solved my issue (at least for now): I used my other (commercial) Autodesk account to download a trial version of Fusion, logged in via that account, and was able to work on my model normally -- no problems, no lag.
For comparison:
Load time-to-menu: Existing account: 01 min 26 sec
"New" account: 0 min 16 sec
For confirmation, I logged out of "new", went back to "existing", and the same problems occur. Back to "new", and things work as expected.
I would prefer to keep both existing accounts so I can separate the "hobby" stuff from my day job. Also, I have a couple dozen project folders, and I don't relish the idea of transferring everything.
Help fixing my Fusion account would be appreciated. I'm happy to provide logs, login details, etc. (there are no proprietary projects).
Thanks!
