Announcements
Bug: All sketches in Edit in Place are visible
etfrench
Mentor Mentor
etfrench
When editing a sketch while Edit in Place is active causes all sketches in the component to be visible.  Toggling the visibility icon on a sketch has no effect.   Needles to say, it makes it difficult to make edits to the active sketch with all of the other geometry visible.
p.s. I would attach the file to the thread, but exporting it crashed Fusion 360.
ETFrench
dsouzasujay
Hi @etfrench
Sorry to see that you're facing this problem. This looks like a visibility over ride bug.
Would you be able to share the dataset (Sujay<dot>dsouza<at>autodesk<dot>com), I tried with a simple design but couldn't reproduce.
If you find my answer solved your question, please click the "Accept Solution" button
Sujay D'souza
SQA Manager
Quality Assurance
Autodesk, Inc.
