Announcements
Bug. 10-32 UNF modeled thread!
HughesTooling
HughesTooling
If you set the Class to 2A the thread fails, works OK with 3A. Also if I set the thread to UNC it models correctly with 2A and 3A. Model is attached just edit the thread and change the class.
Mark
Mark Hughes
Owner, Hughes Tooling
Replies (10)
MR-R
I was having trouble modeling a simple 10-32 UNF thread and came across this thread.
Does anyone know if there is a fix for the error?  I'm wanting to create a piece of threaded rod so that I can create an assemble with two other parts, both of which were able to be modeled with 10-32 UNF internal threads.
I know that changing to 3A as mentioned below is one way around the error, but my internal threads are class 2.
HughesTooling
@jeff_strater  Looks like this post was missed!
Looking through the XML file it looks like a typo for the pitch diameter, it's set to 0.6673. Probably should be 0.1673
Mark Hughes
HughesTooling
@MR-R  I've attached the UNF XML file with the pitch diameter set to 0.1673 and it seems to work OK. If you do a search for ANSIUnifiedScrewThreads you should be able to find the directory with all the thread XML files. Just be aware when Fusion updates you'll probably need to manually update the file again.
Mark Hughes
TrippyLighting
@jodom4 can we get this fixed?
Looks like extremely low hanging fruit.
TheCADWhisperer
@TrippyLighting
Picked, dewormed, washed, peeled and diced by @HughesTooling .  Ready to be baked in the pie.
rhdfmail
Noticed somethin similar, but for metric threads when using hole-command.
A tapped M5 hole without the tread modelled, when measured its 4,234mm. wich of course  is based of some of the dimetions of the actual thread. Would be nice if the hole would be the recomended drillsize
seth.madore
@rhdfmail wrote:
..Would be nice if the hole would be the recomended drillsize
Well, that might become a bit of a Pandora's box right there. What's the desired percentage of thread? What's the material? Are we using a form or cut tap?
Seth Madore
rhdfmail
Yep..
But following scenario is possible.
Someone designs a part and uses the hole-command for all threaded holes.
I program the part and sees M5-thread on the drawing and doesn't measure the holes and instead imports my "drill & threadmill for M5" template.
Here 2 things can occur.
#1 I have seen by threaded holes in solids before where the hole for a M5 can be anything between 4 and 5 mm and tuned my drill-operation to just use 4,2mm holes (so I notice when holes that is supposed to be included isn't)
Here I then have to either change the holes in the solid or adjust the drilloperation AND the threadmilling
#2 I didn' do that and instead specified 4 -4,5mm
This means I will drill a correct hole at the right spot, but my threadmill-op will use the 4,234mm hole and apply its diameter offset from that (because someone thougt that approach for treadmilling was a clever idea)
This means I will get a bit too big threads (not much but  noticable)
If I would design every part myself that would not be a problem. Just adjust my template to correct values. But 99% of what I run is designed by someone else.
jeff_strater
thanks for reporting this.  Created FUS-74291 to track this bug.
Jeff Strater
Engineering Director
jeff_strater
This problem has been fixed in our development version.  I'm not sure exactly what update this will appear in, but it should be relatively soon.  Thanks again for reporting the bad value in this thread spec.
Jeff Strater
