Browser tree bug in Design. It is only visible by a little bit?
I Came back to my design work space after finishing up a Drawing blueprints (to export to pdf for manufacturing guys) and found my Browser tree had been chopped! Shrunk! Truncated! Shrivelled!
I closed the file and oppened it again, same issue.
Restarting Fusion fixed the issue.
rishabh.bisht
Can you try Reset to Default Layout (under FILE>VIEW) OR Hide Browser Followed by Show Browser?
Rishabh Bisht
Product Owner
I had tried to Hide and Show the browser, which did not fix the issue.
I will try Reset to Default Layout if the issue comes up again. It has been working fine since I restarted Fusion 360.
