Browser keeps moving around
mlitzkow
mlitzkow
I have run Fusion 360 on a dual monitor setup for a long time without much trouble. However, sometime in the past week or so, my browser became detached from the main Fusion window and moves itself around for no reason I can see. Often it's on the left monitor while I am running Fusion on the right monitor. I keep trying to put it back, moving it until the "green line" appears doesn't really seem to work for the right monitor. If it move the main Fusion window to the left monitor, then I can dock the browser using the green line. Then I can move my main Fusion window back to my right monitor (where I like it), and the docked browser moves with it and things seem OK. However, later when I click on an item in the browser it will jump back over to the left monitor. Sometimes it stays on the left, and other times as soon as I collapse the menu from clicking on the browser item, it moves back to the right monitor. This seems like a bug, but maybe it's a feature. If it's a feature, it's not one that I intended to activate, and I need to know how to turn it back off. Thanks in advance for any help you can provide.
TrippyLighting
I have no idea if this works but it's worth a try.
Have you tried "View->Reset to default layout"?
P.S. that behavior is definitely NOT a feature!
mlitzkow
Based on your suggestion I tried "Hide Browser" and then "Show Browser". It looks like that may have worked, but I haven't really used Fusion much since doing it. If that doesn't work, I will try "Reset to Default Layout".
