Announcements
browser keeps disappearing on MacOS
jandyman
jandyman
This has started happening to me fairly regularly now. I get into a state where the browser disappears when I click in the workspace. If I move the overall app window by dragging, it reappears, only to disappear when I click inside the window.
See the attached video.
What is going on here? The only way I know to get out of this state is to quit Fusion 360 and start it again. It's getting tedious.
rprovideo
I had this. Go to view, hide browser, then show browser. Didnt happen in a few days now.
jandyman
Yeah, I tried that, it's not helping.
RajkumarIlanchelian
@jandyman I am asking around internally on this one but just a few things to try and information.
1. Which macOS is this and are there any pending updates?
2. Likewise for fusion any pending updates?
3. If you run Fusion in full screen mode, does the same repeat?
4. If you say dock the browser in the right side Does the same repeat? Or does simply re-docking help?
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
FrodoLoggins
Not OP but this has probably happened to me multiple times every single workday for the past ~5 years.
1 M1 Max rMBP and 2 Intel rMBPs.
Every version of MacOS/Mac OS X I've had over the past 5 years
Every version of Fusion I've had for the past 5 years
I never run Fusion in fullscreen mode
OP, opening quicktime usually snaps the browser back. Don't need to do anything within QuickTime. Literally just open it and force quit it. Or enable mission control and it'll show all your open windows (The browser should be isolated as if it's a separate program/window):
Should go back temporarily but you'll have to keep doing that.
- Time Magazine’s Person of the Year 2006
- Apple M1 Max rMBP A2485 // Latest MacOS // Latest Fusion
- Usually working off files uploaded to Fusion as: Step, STL, SLDPRT. If it matters ask me.
jandyman
I've updated my OS to the latest, and so far I have not seen this happen again, but I have not been using Fusion heavily since. I will report if I see the problem again. I let Fusion update itself whenever it wants, so I assume it is up to date. I have seen the problem in both full screen mode and windowed mode, but normally see it enter this mode from windowed mode. Docking the browser does not help - the docked browser "tab" will then disappear just like the browser itself, with he same behavior
