Browser arrows not working
juanZHCDN
juanZHCDN
Some of dropdown arrows (and the visibility toggle on/off) on the browser in the Drawing environment very often don't work.
I am using a 2022 new MacBook Air.
M2 chip
8GB memory
Sonoma 14.1
Replies (11)
ryan.bales
Autodesk Support
Autodesk Support
Screenshot/video something to show this?
Ryan Bales
Fusion 360 Product Support
juanZHCDN
Hello Ryan,
Thank you for looking into this.
Please see the video attached.
You can't see every time I'm clicking but it is whenever I'm staying over an arrow or view on/off icon. Some of them work and some don't.
Thank you,
Juan
juanZHCDN
Hello Ryan,
Did you have any luck with this?
Thank you,
Juan
ryan.bales
Autodesk Support
Autodesk Support
I hadn't seen your video. I'm not seeing that on my end, i'm on an M1 with Sonoma 14.4.1 and it works normally for me. This happens on every drawing?
Ryan Bales
juanZHCDN
It happens on every drawing pretty much, yes.
ryan.bales
Autodesk Support
Autodesk Support
Hmm do you have High DPI enabled in Display preferences?
Ryan Bales
juanZHCDN
Yes, please see attached.
ryan.bales
Autodesk Support
Autodesk Support
I don't think anything was attached. But i'm not sure what else to try, if its not graphical - which it still could be. Have you testing repairing Fusion?
Ryan Bales
juanZHCDN
Here's the attachment.
How do I repair Fusion?
ryan.bales
Autodesk Support
Autodesk Support
You should be able to launch the service utility from Launchpad or find it Spotlight. There you can repair Fusion.
Ryan Bales
juanZHCDN
Good morning Ryan,
I have repaired Fusion but that didn't work. I also uninstalled and re-installed it, but the issue persists. Here's a new video, in case that helps.
Thank you,
