Announcements
Browser access to Fusion 360 - saving post processing file using a mac
a.sooriasegaram
a.sooriasegaram
Hello,  would anyone know a work around for this? As the latest version of Fusion on a mac requires an OS above 10.13 (High Sierra) which isn't viable for me right now -   as a last resort I'm having to use the browser access for educational use which isn't too bad -  however the software seems to be assuming the user is on a pc  (see screen shot) and I can't work out how to save a post processing file locally to my mac book or a USB so I may then practice  machining.
I'd be grateful for any suggestions, thank you,
Ahilan
HughesTooling
If you right click the setup or ops you want to post, select Create NC Program you then have the option to save the output to a project on your hub. From there you'll need to download the file.
Mark Hughes
Owner, Hughes Tooling
a.sooriasegaram
Thanks a lot Mark!
