Boundary Fill Remove Tools Repeatable Bug
stefan0p
stefan0p
Please see the screen recording for the workflow.
If inserting a component into a design, and using boundary fill to 'clone' its body (and using remove tools), inserting that component again into a new design will insert it without the body that was removed previously.
Essentially remove tools is affecting any future inserted referencing of the design, without altering the design itself or creating a new version.
macOS 15.3.1 (24D70) on Mac16,5
MacBook Pro M4 Max
TrippyLighting
Can you share that design? (export as .f3z and attach to post)
I can't share that one as it is a part of current work, however I just tested the issue again by making a primitive cube and using boundary fill remove tools in that workflow. Ut will repeat the same issue, no mesh body needed in the file.
